Old 05-31-2006, 10:43 PM   #1
Godluvsugly21
My Ride: 2001 325i Sedan
Camshaft Position Sensor (Exhaust) DIY HELP!!
I recieved a P0369 Code, and I found out that the Camshaft Position Sensor B code is for the exhaust side. I purchased a replacement CPS and now am having trouble finding a DIY with pics. I know it is probably an easy install, well at least easier than the Intake. Does anyone have any insight or pictures to help me? I would really appreciate it. Thanks!!!!
Godluvsugly21 is offline   Reply With Quote
Old 06-14-2006, 06:00 PM   #2
GUNIT
My Ride: 2011 328i
I have the same problem. Does anyone have the DIY?????
GUNIT is offline   Reply With Quote
Old 06-16-2006, 02:33 PM   #3
Blinky330xi
My Ride: 01' 330xi
subscribe...
CAN'T I LIVE WHILE I'M YOUNG!
"Life may not be the party I had hoped for, but while I'm here I might as well listen to the music and dance!"
Blinky330xi is offline   Reply With Quote
Old 06-19-2006, 09:57 PM   #4
dellop
My Ride: 2001 325xi
The exhaust side is very easy. It is a black sensor located on the front of the engine, toward the passenger side. Disconnect the wiring harness, and remove the single mounting bolt. It is located right next to the VANOS control unit (gray cylinder).
dellop is offline   Reply With Quote
Old 06-19-2006, 10:11 PM   #5
Gir
My Ride: .
Gir is offline   Reply With Quote
Old 06-20-2006, 06:58 PM   #6
Peas
My Ride: 323i
BMW 323i
Thanks Gir and Dellop. My g/f has a BMW 323i (2000) that is giving error code P1397. That turns out to be a Camshaft Position Sensor, Circuit B (exhaust side). Hopefully I'll be able to use your advice successfully
Peas is offline   Reply With Quote
Old 06-27-2006, 03:44 AM   #7
indosoul
My Ride: 02 325ci Sport
Send a message via AIM to indosoul
any good places to buy? i'm searching around, but i'm sure someone already did the dirty work and found the best deal.. or is it one of those things that you have to go to the stealership?
'02 Alpine white 325ci Sport Package 5-spd
Mod List:
K&N 57 series intake, BMW Performance SSK
'99 Jet Black 323i 5-speed (SOLD)
Mod List:
Short ram intake, ashtray garage door opener, chrome gauges, ACS pedals, H&R race springs, Bilstein struts, Hartge exhaust, 19" PG2 reps
indosoul is offline   Reply With Quote
Old 06-27-2006, 05:18 AM   #8
EDawg
My Ride: :/
the exhaust camshaft sensor is attached with 1 torx head screw. make sure you have the right size torx bit before you attempt to remove this screw. otherwise, it will be very easy to strip this screw, which is what happened to me, and you'll then have a helluva time trying to get that screw off.
EDawg is offline   Reply With Quote
Old 08-07-2006, 11:28 AM   #9
bls_brandon
My Ride: 1999 323i
Go to autozone. I ordered the aftermarket exhaust camshaft position sensor for $35 and it will be here tommorow. 1 day! Couldn't find one for less than $100 on the 'net.
bls_brandon is offline   Reply With Quote
Old 08-07-2006, 06:59 PM   #10
Jred
My Ride: 2000 328Ci
I've got a 2000 328Ci which had to have the sensor replaced about 2 years ago.
What held it in place was a 5mm hex (Allen) head screw, not a Torx. I would try the Allen head first to see if you get a good fit. Also, I bought the sensor (12141438082) from Bavarian Autosport for $96, plus the O-ring (12141748398) for $1.50. There may be a newer part # for the sensor though, not sure.
Lastly, the connector is a bit tricky to remove the first time. You just have to be persistant.
Jred is offline   Reply With Quote
Old 08-09-2006, 07:07 PM   #11
aznballer24
My Ride: 2001 330i
exhause camshaft sensor
I went out there to try to replace the exhaust sensor but there is hardly any room to work. For those who have done it, what did you end up having to move to clear space. Or did you not have to clear any space...
My other question is, can you give a picture of where the intake camshaft sensor is. I can't locate it. A picture like the one attached to this thread would be super.
Thanks a whole lot.
aznballer24 is offline   Reply With Quote
Old 08-10-2006, 11:11 AM   #12
hummer
My Ride: 2001 330CI
Thanks a whole lot.
SEARCH This has all be discussed before with pictures. The intake sensor is on the intake side of the head under the vanos solenoid which is visible in the upper right hand corner of the picture in this thread. Solenoid must be removed to gain access.
Old 08-10-2006, 08:09 PM   #13
sdewage
My Ride: X5
I have a private message received from 'AIRCER' on this, I can forward it to you if you need it. Let me know. I haven't done it myself yet, but he has so much info in the message. Btw, can I ask you howmuch the part was ?
2006 4.4i LeMans | Skid Plate | 20" XIX X05 |
sdewage is offline   Reply With Quote
Old 08-28-2006, 09:04 AM   #14
Mautofied
My Ride: 02 BMW 325Ci
sdewage... can you forward that message to me? THANKS!
Mautofied is offline   Reply With Quote
Old 08-28-2006, 07:58 PM   #15
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Do not buy the after market sensor we have ahd major probelms with the aftermarket one causing odd faults and reading I onl;y order OEM now to put on at our shop!!
jbeurotech is offline   Reply With Quote
Old 10-22-2006, 02:09 PM   #16
rudetrini
My Ride: 2001 325ci
do coupes and sedans have the same part #'s for the camshaft sensor?
rudetrini is offline   Reply With Quote
Old 10-25-2006, 06:54 PM   #17
vaio76109
My Ride: Race Cars
Yes.
I just got the(P0369) fault code today. Will any harm be done to the engine if I run a track event this weekend and I don't fix it by then? I'd imagine I'd lose some power.
vaio76109 is offline   Reply With Quote
Old 02-22-2007, 10:47 PM   #18
Yellowmann
Rolling on Dubs. Got Boost?
My Ride: AA SC Y2K 323i
Send a message via AIM to Yellowmann
Thanks for the info... Im having a fault code too and have to check into this.
Once A Yellowmann, Always A Yellowmann ...One Who Is Wise - Always Learn From Other People's Mistakes ...One Who Thinks That They Can Never Be Successful - Will Never Be Successful ...First You Don't Succeed - Try, Try Again ...
Yellowmann is offline   Reply With Quote
Old 02-23-2007, 08:22 PM   #19
BMWF18
My Ride: Truck
When you have problems with the cam sensors, I would recommend you try to fix it ASAP. It probably will not harm your engine, but why risk it.
Also for the guy asking what to move, nothing. Get a ratchet and a 5mm hex, pull old one out and replace both sensor and O-ring. It can be done, trust me. And as long as you have an M54, or same engine as each other the part should be the same.
BMWF18 is offline   Reply With Quote
Old 03-04-2007, 07:07 PM   #20
beauch3
My Ride: BMW 325
Is the bolt that I have to remove to get the sensor out just above and to the left of the black sensor in your picture? This appears to be a bolt that can be removed with a metric ratchet. What is the 5 mm hex for?
beauch3 is offline   Reply With Quote
