Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#1 |
Eurowise's E46 M3 Turbo build
We've been working on a custom M3 turbo build for quite some time now on and off. You may have seen pictures leaked on the forums back in the day. Over the last year we've been swamped with work and haven't had a chance to touch it until recently. Last weekend we did some final touches on the turbo setup and put her on the dyno for some tuning. Results were great overall. Even with the turbo mounted remotely, there's actually minimal turbo lag unlike what most people think.
We're currently running a Precision 6266 ball bearing billet turbo. With the 68ar turbine we achieved full boost at around 4,800 RPM's. Combined with the Pro-efi's traction control program it delivers amazing power to the ground with minimal slippage. There's more testing to be done as our air-water intake manifold was only built to withstand low boost. The final results were 525rwhp @ 7,800 RPM's 383 rwtq @ 6,200 RPM's boost 14.7 PSI 93 octane Our next plan is a complete motor tear down and Forged rods, pistons, and head studs. ![]() ![]()
#2 |
14.5 lbs Of boost on 93 octane with stock internals?
2006 E46 M3 HPF stg II SOLD
1988 E30 M3 Touring Class 1995 E36 M3 I-Prepared Class |
#3 |
Well done.... Ive had nothing but good service from eurowise :-)
Never been a fan of these remote turbo's but hey if it works, smooth that intake out alittle and youll have a solid setup.....
bmw z4m. vt2-525.. 8psi pulley..
#4 |
#5 |
Thats one way to skin a cat. Looking good!
#6 |
That's a neat setup! Definitely more room there for the turbo. Is that setup less efficient than having the turbo right off of the manifold? Also wouldn't it take a longer to build boost because you have all of that extra pipe you have to fill with air?
#7 |
At 525rwhp, it looks like a pretty conservative tune. 14.7 psi on stock internals probably won't be an issue.
#8 |
That is the general consensus with rear mounted turbos. But in some cars its the only option. However if you're mounting a 62mm turbo I would have thought there would be no reason not to put it up front.
#9 |
Oh, btw any videos. I'm curious what that sounds like!
#10 |
Why not run 6 lbs like we do with a slightly more aggressive tune?
#11 |
Congrats!!! The exhaust sure doesn't have far to go.
Chris.
![]() ![]() HorsepowerFreaks.com 12905 NE Airport Way Portland, OR 97230 (503) 256-5600 BMW Performance Parts Product questions or to purchase - sales@horsepowerfreaks.com |
#12 |
These motors have been known to handle 700+ HP on stock internals.
We originally went this route to make turbo installation simple. keep costs low on hardware, Retain factory cats to pass emissions, and draw heat away from the engine bay. It's more of a test vehicle and a project we've been toying around with. Nothing going into production Videos coming soon. Car sounds like an airplane getting ready to take off. Pretty sick if you ask me! Thanks, for the feedback bud!
#13 |
My Ride: 05'M3, 03 996TT
Nice work guys, turbo looks sexxy back there. The sound from the rear under boost must be music to the ears. Those are impressive numbers for 93 pump gas though. More info on your impressions of the ProEFI traction control and if possible some vids
M3: Best ET 11.93 Best Trap 134 996TT: Best ET 11.36 @ 124.24 w/ 1.65 60' Last edited by 02black330ci; 03-15-2012 at 08:33 PM. |
#14 |
The spool is going to be loud as hell!
#15 |
Get sick with it!!
#16 |
ninja editor
hardware looks great!
Being a smaller turbo than what HPF uses for stage 1-2.5, this entire curve has been moved to the right. On 93 octane and stock compression, that's a lot of boost, but it seems like you're ready to build the engine. Though, this would still probably last a long time if you dont abuse your motor too much, especially given how far to the right the power curve sits. While I totally respect this entire setup, I must state that if the turbo were to be mounted directly on the engine, I suspect over a 1.5krpm spool improvement... I bet that turbo spool sounds so sick though
#17 |
how much have you invested so far?
#18 | |
Too much at this point to keep up with!
#19 |
My Ride: 2004 E60 530i 6speed
Wow, Thanks Mike for starting this thread as I've wanted to follow the progress. You know already I support the rear mounted idea and as of last week I had the pleasure of meeting Mike in person and taking a tour of his shop/shops LOL They are busy with all sorts of projects. I got a chance to see the M3 up close and in person as well another project they are working on that has my interest. Mike did you get the final numbers on that M54B30 car with ProEFI yet. If you don't want to disclose here please PM or call me with results. Keep up the great work and thanks again for posting your build.
![]() ![]() ![]() 530i E60 Custom Turbo/Nitrous (PSI_unknown) |
#20 |
Good stuff guys.
E46 M3 GT4088R ProEFI tuned...Sold
SL55 AMG...build in progress |
