E46 Xi Forum
The E46 XI was produced from 01-05 in sedan and touring body styles. Powered by either a 2.5L inline 6 in the 325xi or a 3.0L inline 6 330xi. Discuss all thing about BMW AWD E46 'Xi' here. |
#1 |
Have Bilstein HD Shocks - Rear Spring Recommendations?
Just found out the rear springs have cracked. I don't want to buy OEMs to watch it happen again. I've already replaced all four shocks/struts in the car with Bilstein HD's. Just wondering if anyone with Bilstein HDs has replaced their rear springs and can recommend a brand? I'm open to replacing all four springs, which might not only be necessary but also cheaper than just replacing the rear springs with OEMs. Thanks in advance.
#2 |
Eibach springs for xi will be perfect.
#3 |
#4 |
Has anybody tried these springs?
http://www.fcpeuro.com/products/bmw-...n-suplex-06047 They also make a complete kit with mounts http://www.fcpeuro.com/products/bmw-...plex-06164kit1 |
#5 |
Same issue here. New HDs front and rear. So no issues with Eibach springs? Will they lower the car?
Never really thought about lowering my xi, but the gap on the front is hideous.... |
#6 |
Banned User
My Ride: 2003 325i stick
I have the same setup. Bilstein hds with oem springs.
The gaps dont bother me and are really not something that is hideous |
#7 |
My Ride: 2003 325xi
Eibach springs will lower the car. They also list the XI 325/330's "pro-kit" under a different part number. Something is specific to XI's. The fcpEuro site should list the exact XI part number crossed from the OEM number.
Anything made can be made Better ![]() |
#8 |
The best all-around xi setup is:
-Bilstein HD struts for xi -Bilstein shocks for e36 m3 -Eibach springs for xi Koni struts/shocks for xi can also be used with eibach or oem springs. Eibach springs give a one inch drop. HnR springs will give a two inch drop, but a much harsher ride than eibach springs. If you want to use HnR springs, substitute Bilstein sport struts for xi from the list above. If you want to keep the oem springs, don't use the m3 shocks- use bilstein HD for xi all around (or Konis). |
