Sponsored by The Tire Rack
Old 08-13-2012, 11:04 PM   #1
2J-SCREAMER
My Ride: 323Ci
Yet another non m fitment question :(
Is anyone running 19x9.5 et +35 on the rear of their E46 non M coupe ? And if so, what tyre size ?
Or does anyone know if this will fit without too much drama ?......I want to run reasonably low, but not crazy as it's my daily ride.
Searched for this, but can't find anyone running this exact setup
Any help greatly appreciated
Really sorry if this has been covered a million times, but I'll be stuffed if I could find the info I'm after......
2J-SCREAMER is offline   Reply With Quote
Old 08-13-2012, 11:06 PM   #2
Trashcan
My Ride: 2002 330ci
Jizzo330 is running them. Check pyspeed.com under vmr v710s and the tires they recommend fit perfect
Trashcan is online now   Reply With Quote
Old 08-13-2012, 11:39 PM   #3
e46brat
i <3 my e46
My Ride: 2001 330ci
I'm running that exact setup on the back with some Toyo 255/30r19 tires. My drop would be moderate/low but not slammed. I'm rubbing a lot even on little dips with a fender roll as well. I can camber my wheels in a little bit beyond the factory specs I suppose, but I do not want to kill my tires prematurely as well. So if I were u, I'd suggest either getting a narrower tire or lower your car just a bit (as I had little rubbing on the rears when my car was raised up about 3/4 to 1 inch).
Hamann/Euro-Spec/AA/Tein/Work Meister
e46brat is offline   Reply With Quote
