So ever since my ccv froze the other week I've been keeping a close eye on everything with my bluetooth adapter and torque pro android. No CEL codes but when I run the test option I get the following results. All passed except this. I googled this for awhile but can't seem to figure out what it means. Any ideas or similar results?
TID:$05 CID:$07
- Rich to Lean sensor switch time(calculated)
Min: 3,932
Test result value: 2,116
FAIL
Full test results.
TID:$05 CID:$07
Min: 3,932
FAIL
Full test results.
Code:
Mode $06 report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: 7528050
7532346
Unit and scaling information are not supplied with the data from the ECU for this type of vehicle. Consulting the manufacturers service book for this information is recommended.
Test report:
TID:$01 CID:$01
- Rich to Lean sensor threshold voltage(constant)
Max: 269
Test result value: 39
PASS
TID:$01 CID:$02
Max: 269
Test result value: 28
PASS
TID:$02 CID:$01
- Lean to Rich sensor threshold voltage(constant)
Max: 1,029
Test result value: 456
PASS
TID:$02 CID:$02
Max: 1,029
Test result value: 369
PASS
TID:$02 CID:$03
Max: 65,535
Test result value: 415
PASS
TID:$02 CID:$04
Max: 65,535
Test result value: 433
PASS
TID:$02 CID:$05
Max: 1,029
Test result value: 367
PASS
TID:$02 CID:$06
Max: 1,029
Test result value: 314
PASS
TID:$02 CID:$07
Max: 65,535
Test result value: 363
PASS
TID:$02 CID:$08
Max: 65,535
Test result value: 264
PASS
TID:$02 CID:$09
Min: 104
Test result value: 126
PASS
TID:$02 CID:$0a
Min: 104
Test result value: 134
PASS
TID:$03 CID:$05
- Low sensor Voltage for switch time calculation
Min: 440
Test result value: 440
PASS
TID:$03 CID:$06
Min: 440
PASS
TID:$05 CID:$07
Min: 3,932
FAIL
TID:$05 CID:$08
Min: 3
PASS
TID:$05 CID:$12
Min: 2,458
Test result value: 4,473
PASS
TID:$05 CID:$13
Max: 6,554
PASS
TID:$05 CID:$14
Max: 4,145
Test result value: 3,414
PASS
TID:$05 CID:$15
Min: 3,623
Test result value: 3,625
PASS
TID:$05 CID:$16
Min: 4,473
Test result value: 4,475
PASS
TID:$05 CID:$18
Min: 0
Test result value: 65,535
PASS
TID:$06 CID:$01
- Lean to Rich sensor switch time(calculated)
Max: 9,662
Test result value: 60
PASS
TID:$06 CID:$02
Max: 11,435
Test result value: 54
PASS
TID:$06 CID:$03
Max: 12,503
Test result value: 37
PASS
TID:$06 CID:$04
Max: 12,000
PASS
End of report.
