Quarter window trim
5.3K views 5 replies 3 participants last post by  Daylight
#1 ·
Hiy evryone i got problem with this trim its 2005 coupe and shadow line trim need solution cous its very expensive thing in my country thanks from now
#4 ·
My original trim is the silver aluminum finish, but I switched to black.
I found used 51717003935 (left) and 51717003936 (right) black trim pieces from a part out, got both for $100.
I also bought matching black lower 51368194741 (left) and 51368194742 (right) window trim pieces new for around $30 each.
It is not worth the money and hassle to replace them just for the crumbling black rubber strip. Just cleanly cut it away so it’s not noticeable and you’re good.
#5 ·
It is easy enough to replace the rubber for an OE look for dirt cheap. Certainly worth spending a Saturday on.
Sent from my Pixel 3 using Tapatalk
