SOLVED! cooling system issues
1 reading
7.1K views 40 replies 8 participants last post by  qns_chris
#1 · (Edited)
UPDATE 12/13/23 - SOLVED! see post at bottom of thread.
Hi all - I'm new to the community, but have read countless DIY and troubleshooting threads, and I now humbly come seeking assistance -
A week ago, after dropping my son off at school on one of the first cold days of the year, I returned home and smelled a burnt, slightly sweet smell. I opened the hood and was hit by a thick vapor of the same scent that stuck to my clothes.
When the car had cooled down, I checked the coolant level and the floater was at the bottom of the expansion tank. I added coolant - enough to bring the level up between max and min - and said a prayer.
Since adding coolant, I've noticed several issues:
  • Temp gauge is 1-2mm to the right of TDC once the car warms up (see dash pic) - on my most recent trip, the coolant temp range was 94-96C
  • A grinding noise at idle with the hood up that sounds like its coming from the water pump / water pump pulley (see video)
  • Small splatters on the side of the expansion tank (see expansion tank pic)
Some relevant background on my car:
  • 2002 325i manual, M54, 74k miles
  • Replaced cooling system in May 2023 with FCP's "BMW Cooling System Overhaul Kit with Water Pump" plus Radiator
  • Upper/Lower Hoses - Vaico/Rein
  • Coolant Return Hose - Rein
  • Water Pump - Graf
  • Thermostat - Wahler
  • Expansion Tank - Rein
  • Expansion Tank Retainer - Rein
  • Fan Switch, Level Sensor, Tank Cap, etc.
  • Radiator - Nissen
  • Water Pump Pulley - Febi Bilstein
  • Replaced VANOS with refurbished Dr VANOS unit
  • Replaced cracked Valve Cover with Aluminum MITZONE Valve Cover (plus VCG)
Please help! Has anyone had similar issues? I want to bring her to my local Indy BMW shop, but am paranoid about overheating on the way over.
Thank you in advance!!
#2 ·
1. Engine off, feel around water pump and Tstat for wetness.
2. Search for Sapote’s bleeding method and use it to bleed air out, as praying won’t help the air out.
  • Like
Reactions: qns_chris
#4 ·
Thanks Sapote - am planning on bleeding, thanks for the instructions.
I’ve visually and physically (above and below the car) inspected the hoses around the radiator, tank, and thermostat - all are dry as a bone.
Praying has never produced results on any of the cars that I’ve owned :LOL:
#5 ·
Thanks Vpoint - that’s what I thought too, but want to get confirmation from the shop. They’re about 15 miles away, but with traffic / side streets / stop&go traffic, it could easily be a 30-40 minute trip. I’ve still got the 50/50 coolant mix in the garage, will throw that in the trunk on the way over.
#7 ·
Thanks tks - that would explain the grinding noise and the smell/vapor that hit me when this all started. I’m taking her to a local Indy shop tomorrow to get the cooling system diagnosed - will go from there. If it is the water pump, thank god for FCP’s lifetime warranty
#10 ·
I would do this: remove the engine bottom plastic tray if it's still installed, run engine and let idle until temp got to 93C, turn off engine and get under it to look for leaking around radiator bottom, hoses, water pump, Tstat, tank bottom, left side of engine block. At the moment the coolant pressure is high and any leaks should show up.
#14 ·
Was there any coolant residue on the plastic splash panel? (Sounds like a no.)
Fyi, here is a picture of the green waterfall behind the OFH to look for. This leak wont drip on the ground, but worth a quick check.
The air filter box, upper intake boot are removed (so is alternator but that's not needed to check).
Second pic is with intake removed:
#23 ·
I suggest you unlock the secret cluster menu and get a numerical reading of the coolant temperature. 1-2 mm to the right of center with a temperature gauge that is buffered, on purpose, is not a good way to assess and diagnose. Under normal operating conditions, you should be somewhere between 94-98 degC. It won't be an exact rock-steady number because of various operating parameters. You can have this menu item unlocked while you're driving so you can keep your eye on it.
#29 ·
That too.
One time with a water pump failure in a truck, I used a 5 gallon water cooler bottle, filled with tap, then refilled with water every mile or so to get the 6 miles home
#30 ·
That too.
I've refilled from a ditch.
:LOL:
Normally I'd agree with the above two posts, but it is winter and if temps are below freezing (one of the dash pictures shows 32F), then using only water risks the water freezing (expanding) and really causing problems like a cracked head.
This is a fair point.
#32 ·
Yeah, it’s getting cold here on Long Island. I took her out for an hour and kept the Bluetooth feed up - she didn’t cross over 96C, engine was purring. Now to pull out my UV flashlight and find this stupid leak. My money is on the water pump, maybe the tank, and maaaaybe the thermostat.
#33 ·
@qns_chris
Deja vue - I was visiting my folks (in CT) and I started the car with a squeal / screeching on startup. Once that happened after 30 sec's no issues.
I too had a newly replaced cooling system after buying a new to me e46. I replaced the entire system (except radiator) in Late 2020. Too soon for a failed WP...
I did the remove the splash shield and I was lucky (sort of) that there was BLUE coolant under the car. DAMN....
Filled the car with Distilled water, drove it home (no issues) and once I got it home 24 hours nothing... HMM... but a day later blue puddle.
Failed FCP purchased (YES!) OE Saleri pump had play in it... DAMN !!! replaced the pump, pulley, T-Stat (just in case) and no issues so far.
Not sure if there was a bad batch of WP but 2.5 years on WP with only 30k mileage is not right, only good thing is i got the price back from FCP under warranty.
I bought the STEWART pump which lasted me on my older e46 almost 100k miles and its still going (e46 @ 225k).
Fingers crossed.
#34 ·
@qns_chris
Fingers crossed.
Counterpoint - I've gotten 100k out of a Saleri water pump.
Twice, I guess, since the original one would have been Saleri and wasn't replaced until 135k.
#36 ·
Solved!! Update 12/13/23
After finishing my oil pan gasket (what a PITA that was) and lowering the engine, I heard a sustained "hissing" sound from the expansion tank area, which lasted about ten seconds. I visually inspected the area, still as dry as a bone.
I took her for a test drive - about 20 miles - and upon returning and opening the hood, I found green dye (that my indy had put into the tank a week earlier) all over the top of the tank, leaking clearly from the smaller connection at the top of the tank (see pics). I pressed the connector / pin in toward the tank, and <CLICK> in it went!
Since then, my temp gauge has stayed TDC like it had been prior to this incident, and she's purring like a cougar.
The fitting most likely came loose from when I had changed the engine mounts a few weeks back, which also involved lifting the engine. I'm certainly keeping an eye out for subsequent leaks, but so far so good!
#37 ·
I can't tell if the leaking is from the smaller connector or from the tank cap by the pic. But it's great that you fixed it.
  • Like
